Ethernet Products
5777 Discussions
update XL710 NVM 6.01
sluon1
I downloaded the latest nvm package (6.01) from this link.
https://downloadcenter.intel.com/download/24769/Non-Volatile-Memory-NVM-Update-Utility-for-Intel-Ethernet-Network-Adapter-710-Series Download Non-Volatile Memory (NVM) Update Utility for Intel® Ethernet Network Adapter 710 Series
When I run the program nvmupdate64e, I got the output saying "update not available" although it finds my version is older (5.05). How can I force the program to update to 6.01?
# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.30.22.3
Copyright (C) 2013 - 2017 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [
Num Description Ver. DevId S:B Status
01) Intel(R) I350 Gigabit Network Connection 1.99 1521 00:002 Update not
available
02) Cisco(R) Ethernet Converged NIC X710-DA4 5.05 1572 00:004 Update not
available
03) Cisco(R) Ethernet Converged NIC 5.05 1583 00:006 Update not
XL710-QDA2 available
Tool execution completed with the following status: Device not found
Press any key to exit.
# cat version.txt
v6.01
Hi Sluong,
Thank you posting in Wired Ethernet Communities. The output shows Cisco Cisco(R) Ethernet Converged NIC X710-DA4, if this is an OEM version from Cisco, you need to contact Cisco (the OEM vendor) for the customized firmware. The firmware available on our website are generic version suitable for Intel retail version of X710 network adapter.
Hope the above information help.
Sharon T
Intel Customer Support
Agent under contract to Intel
Hi Sluong,
Please feel free to confirm if you have contacted the OEM vendor in case you are using the OEM NIC version. Thank you.
Sharon T
