Ethernet Products
5715 Discussions
vmq and vrss Intel Ethernet Server Adapter X520-2
vsant7
We have several servers with Intel Ethernet Server Adapter X520-2, each server has two cards.
In the documentation says that vmq an vrss are compatible
We do not know why depending on whether you enable the vrss is 31 vmq or 63 with the vrss disabled?
Enable VRSS
PS C:\Users\Administrator.AD01> Get-NetAdapterVmq
Name InterfaceDescription Enabled BaseVmqProcessor MaxProcessors NumberOfReceive
Queues
SLOT 2 Port 2 Intel(R) Ethernet Server Ada...# 4 False 0:0 16 0
SLOT 2 Port 1 Intel(R) Ethernet Server Ada...# 3 True 0:0 16 31
SLOT 1 Port 2 Intel(R) Ethernet Server Ada...# 2 False 0:0 16 0
SLOT 1 Port 1 Intel(R) Ethernet Server Adapt... True 0:0 16 31
NIC2 Broadcom NetXtreme Gigabit Eth... False 0:0 16
Teaming LAN Microsoft Network Adapter Mult... True 0:0 62
NIC1 Broadcom NetXtreme Gigabit E...# 2 False 0:0 16
Teaming SAN - VLAN 155 Microsoft Network Adapter Mu...# 2 False 0:0 0
Disable VRSS
Queues
Teaming LAN Microsoft Network Adapter Mult... True 0:0 126
SLOT 2 Port 2 Intel(R) Ethernet Server Ada...# 2 False 0:0 16 0
SLOT 2 Port 1 Intel(R) Ethernet Server Adapt... True 0:8 16 63
SLOT 1 Port 2 Intel(R) Ethernet Server Ada...# 4 False 0:0 16 0
SLOT 1 Port 1 Intel(R) Ethernet Server Ada...# 3 True 0:0 16 63
