Ethernet Products
5393 Discussions
we need a NIC that can support multi-rules with different MASK for IPV4 FDIR?
HXZ00
Hi,all
We need a NIC that can support multi-rules with different MASK for IPV4,current we use 82599 but noticed that is only support golal mask with below informatiion in the 82599 datasheet: "The 82599 supports masking / range for the previously described fields. These masks are
defined globally for all filters in the FDIR…M register", my questio n is which NIC can match our requirements.
AlHill
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
HXZ00
Thank you but it doesn't macth my question.
AlHill
Sorry, I was on auto pilot.
Doc
Caguicla_Intel
Hello HXZ00,
Please allow us to check on your query. Rest assured that we will give you an update as soon as possible but no later than 3 business days.
Hoping for your patience.
Crisselle C
Intel® Customer Support
Caguicla_Intel
Hello HXZ00,
Thank you for the patience on this matter.
We'd like to check if you have looked into using Intel Ethernet Flow Director? Sharing the links below for more information on Flow Director.
Which Intel® Ethernet Network Adapters Support Intel® Ethernet Flow Director
https://www.intel.com/content/www/us/en/support/articles/000031907/network-and-i-o/ethernet-products.html
Intel® Ethernet Controller 700 Series: Hash and Flow Director Filters
https://software.intel.com/content/www/us/en/develop/articles/intel-ethernet-controller-700-series-hash-and-flow-director-filters.html
If the link above wasn't of help, please provide the following information for us to further check your request.
1.) What are you trying to do and what is the use case? Kindly elaborate.
2.) What is the intended Operating System to use?
We look forward to your response.
In case we don't hear from you, we will follow up after 3 business days.
Crisselle C
Caguicla_Intel
Hello HXZ00,
Good day!
We'd like to check if the above information helped you on your query. In case you have additional questions and clarifications, please do not hesitate to let us know.
Awaiting to hear from you.
Crisselle C
HXZ00
Thanks you for your response, I think 700 serious NIC cam work.​
Caguicla_Intel
Hello HXZ00,
Appreciate your prompt reply.
If you do not have any additional questions for this request, please be informed that we will proceed with closure after 1 business day.
Thank you very much for your time and cooperation throughout the process. Should you have any other concerns or assistance needed in the future, feel free to post a new question.
May you have an amazing day ahead!
Crisselle C
