Ethernet Products
4875 Discussions
why the cldemote uses here in dpdk21.02?
wyf
In dpdk21.02, it add the cldemote feature. I see it used in the DLB eventdev driver. But I don't understand why it uses here as followed.
>static __rte_always_inline int
>dlb_recv_qe(struct dlb_port *qm_port, struct dlb_dequeue_qe *qe,
> uint8_t *offset)
> cache_line_base = (void *)(((uintptr_t)cq_addr) & ~0x3F);
> *offset = ((uintptr_t)cq_addr & 0x30) >> 4;
> /* Load the next CQ cache line from memory. Pack these reads as tight
> * as possible to reduce the chance that DLB invalidates the line while
> * the CPU is reading it. Read the cache line backwards to ensure that
> * if QE[N] (N > 0) is valid, then QEs[0:N-1] are too.
> * (Valid QEs start at &qe[offset])
> qes[3] = _mm_load_si128((__m128i *)&cache_line_base[6]);
> qes[2] = _mm_load_si128((__m128i *)&cache_line_base[4]);
> qes[1] = _mm_load_si128((__m128i *)&cache_line_base[2]);
> qes[0] = _mm_load_si128((__m128i *)&cache_line_base[0]);
>/* Evict the cache line ASAP */
>rte_cldemote(cache_line_base); // why used here ?
Mike_Intel
Hello wyf,
Since this question involves DPDK, please check with Intel Premier Support for further assistance. See the following for access to Intel Premier Support.
Click the "Access and Log In" to contact the DPDK support https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
