Ethernet Products
x520-sr2
JTerr4
I have pair of supermicro servers with intel x520-sr2. With nic teaming getting 1000's of log events per second stating it received packets on wrong nic. Being a team I can see this as a posibilty, but does it need to flood me with messages about it ?
No matching TeamNic found for packets received from member NDISIMPLATFORM\Parameters\Adapters\
Received LACPDU on Member {27EF013E-0DD4-497E-90A2-7E5AC30E6E84}. Buffer= 0x0180C2000002C4F57C565A6F880901010114008001E0520000021904008031043D0000000214000090E2BA92F1D80000000001001F0000000310050000000000000000000000000000000...
event id 25,26, 27
drivers are the most current -
boatmn810
Hi boatmn810,
Thank you for posting in Wired Ethernet Community.
We'd like to request for additional information regarding your issue to aid in our issue investigation. Thanks in advance.
1. System details - you may use our SSU tool ( https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600) and attach the result in this thread.
2. Any disconnection issue occurred when the logs appeared?
3. Detailed steps of your teaming configuration on the system and switch.
Vince
JTerr4
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"12/04/2017"
Time:"00:00:38.1411889"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Supermicro"
BIOS Mode:"Legacy"
BIOS Version/Date:"American Megatrends Inc. 1.1 , 04/14/2015 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Enterprise Server"
Processor:"Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"2.8"
Sound Card:"Not Available"
System Manufacturer:"Supermicro"
System Model:"X10DRi"
System SKU:"072815D9"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Microsoft Basic Display Adapter"
Adapter Compatibility:"(Standard display types)"
Adapter DAC Type:"ASPEED Technology, Inc."
Adapter RAM:"0.00 GB"
Bits Per Pixel:"32"
Caption:"Microsoft Basic Display Adapter"
CoInstallers:"display.inf,MSBDA,ASPEED Technology, Inc.,ASPEED"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"BasicDisplay.sys"
Driver Date:"06/20/2006 08:00 PM"
Driver Path:"C:\Windows\system32\drivers\BasicDisplay.sys"
Driver Provider:"Microsoft"
Driver Version:"6.3.9600.16384"
INF:"display.inf"
INF Section:"MSBDA"
Install Date:"Not Available"
Installed Drivers:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"(Standard display types)"
Microsoft DirectX* Version:"DirectX 11"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_1A03&DEV_2000&SUBSYS_072815D9&REV_30\5&7A64A51&0&0000E4"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"64 Hz"
Refresh Rate - Maximum:"64 Hz"
Refresh Rate - Minimum:"64 Hz"
Resolution:"1280 X 1024"
Scan Mode:"Noninterlaced"
Service Name:"BasicDisplay"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"ASPEED"
- "Memory"
Physical Memory (Available):"50.71 GB"
Physical Memory (Installed):"64 GB"
Physical Memory (Total):"63.90 GB"
- "NODE 1"
Capacity:"8 GB"
Channel:"P1_DIMMA1"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Noninterleaved"
Manufacturer:"Samsung(date:15/18)"
Memory Type:"Other"
Part Number:"M393A1G40DB0-CPB"
Serial Number:"405FC26D"
Status:"Not Available"
Type:"Synchronous"
- "NODE 1"
Capacity:"8 GB"
Channel:"P1_DIMMB1"
Form Factor:"DIMM"
Memory Type:"Other"
Serial Number:"405FC256"
Type:"Synchronous"
- "NODE 1"
Capacity:"8 GB"
Channel:"P1_DIMMC1"
Form Factor:"DIMM"
Memory Type:"Other"
Serial Number:"405FC24F"
Type:"Synchronous"
- "NODE 1"
Capacity:"8 GB"
Channel:"P1_DIMMD1"
Form Factor:"DIMM"
Memory Type:"Other"
Serial Number:"405FC12E"
Type:"Synchronous"
- "NODE 3"
Capacity:"8 GB"
Channel:"P2_DIMME1"
Form Factor:"DIMM"
Memory Type:"Other"
Hi boatmn810, based on your SSU logs, your system has 2 x540 ethernet controller. Have you tried to create similar team configuration and does it exhibit the same behavior of flooding with event 25, 26, 27?
Vince
Hi boatmn810,
please let us know if you encounter the same issue with the x540 ethernet controller. thanks.
Vince
Hi boatmn810,
Kindly let us know if you still need assistance regarding your issue. Thanks.
Vince
JTerr4
I no longer have the option to use the copper based x540.
Yes I am still receiving the error message.
JBT
Hi Boatmn810,
Thank you for the update. Please provide further information below:
1) Any disconnection issue occurred when the logs appeared?
2) Please provide detailed steps of your teaming configuration on the system and switch.
Sharon T
Hi Boatmn810,
Please feel free to provide the informtion so that we can better check for you.
Sharon T
