Ethernet Products
5736 Discussions
x552/x557 to HPE OfficeConnect 1950 24G 2SFP+ 2XGT Switch(JG960A)
진JinS
Hi, I connected server 10GBase-T port to switch 10GBase-T port with Cat.7 STP cable(length 1m).
Two interfaces are up at 1Gbps speed not at 10Gbps.
= Motherboard: Supermicro X10SDV-4C-TLN4F
- CPU: Intel Xeon D-1518
- LAN: 2x 1GbE via i350-AM2
2x 10GbE via SoC(x552/x557 AT?)
https://www.supermicro.com.tw/products/motherboard/Xeon/D/X10SDV-4C-TLN4F.cfm Supermicro | Products | Motherboards | Xeon® Boards | X10SDV-4C-TLN4F
- OS: FreeBSD 11.0-RC1, CentOS x86_64 1511
- Driver: ix-3.1.13k(FreeBSD), ix-3.1.14(CentOS)
I tried ix-3.1.14 driver installation under FreeBSD but failed to compile.
= Switch: HPE OfficeConnect 1950 24G 2SFP+ 2XGT Switch(JG960A)
- 24x 1GbE port(1-24)
- 2x 10GbE port(27, 28)
http://www8.hp.com/us/en/products/networking-switches/product-detail.html?oid=6887535 http://www8.hp.com/us/en/products/networking-switches/product-detail.html?oid=6887535
After connecting two 10GbE port of server mother board with Cat.7 STP cable, both inferfaces are up at 10Gbps.
Also connecting two switch 10GbE port with same cable, both interfaces are up at 10Gbps.
But connecting server port and switch port, all are up at 1Gbps.
It seems auto-negotiation not work well.
Hi JinSooSuh,
Thank you for the post. Have you tried using the Intel Linux-based driver, we do not have driver for FreeBSD and Centos, but only Linux based driver below
https://downloadcenter.intel.com/download/14687/Network-Adapter-Driver-for-PCI-E-Intel-10-Gigabit-Ethernet-Network-Connections-under-Linux-
Are the drivers used came from Supermicro? If not, have you also check with Supermicro* for customized driver as these are onboard NICs embedded on their system which is part of the system. Changes might have made on the ethernet controller during integration which is beyond our control. The system vendor are in better position provide the driver.
rgds
wb
진JinS
I tried ixgbe-4.3.15 from Intel.
I contacted Supermicro technical support and waiting for response.
진JinS
From Supermicro tech. support:
The X10SDV-TLN4F's 10GbE controller is part of the SoC (D-1540/D-1541).
It is categorized as X552/X557 ixgbe device under Linux and driver support is limited.
Source code can be found on Sourceforge from the following link:
https://sourceforge.net/projects/e1000/files/ixgbe%20stable/
Under CentOS-7.2: ethtool was used to set link speed 10Gbps.
# ethtool -i eno3
driver: ixgbe
version: 4.4.6
firmware-version: 0x800003e7
bus-info: 0000:03:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
# ethtool -s eno3 advertise 0x1000
# ethtool eno3
Settings for eno3:
Supported ports: [ TP ]
Supported link modes: 1000baseT/Full
10000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: external
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: umbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
Rebooting or "# ethtool -s eno3 advertise 0x1020" make link speed 1Gbps.
I installed CentOS for testing purpose and will use FreeBSD as production service.
ixgbe driver 3.1.13-k version of FreeBSD-11.0-RC2 and Intel provided ix-3.1.14 under FreeBSD-10.3 do not auto-negotiated to 10Gbps.
Intel provided ix-3.1.14 under FreeBSD-11.0-RC2 make load failed:
cc -O2 -pipe -DSMP -DINET -DINET6 -DIXGBE_STANDALONE_BUILD -fno-strict-aliasing -Werror -D_KERNEL -DKLD_MODULE -nostdinc -I. -I/usr/src/sys -fno-common -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -MD -MF.depen
d.if_ix.o -MTif_ix.o -mcmodel=kernel -mno-red-zone -mno-mmx -mno-sse -msoft-float -fno-asynchronous-unwind-tables -ffreestanding -fwrapv -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmiss
ing-prototypes -Wpointer-arith -Winline -Wcast-qual -Wundef -Wno-pointer-sign -D__printf__=__freebsd_kprintf__
-Wmissing-include-dirs -fdiagnostics-show-option -Wno-unknown-pragmas -Wno-error-tautological-compare -Wno-error-empty-body -Wno-error-parentheses-equality -Wno-error-unused-function -Wno-error-pointer-sign -Wno-error-shift-negative-value -mno-aes -mno-avx -std=iso9899:1999 -c if_ix.c -o if_ix.o
if_ix.c:4393:3: error: incompatible pointer types initializing 'int *' with an expression of type 'uint64_t *' (aka 'unsigned long *') [-Werror,-Wincompatible-pointer-types]
SYSCTL_ADD_INT(ctx, queue_list, OID_AUTO, "lro_queued",
/usr/src/sys/sys/sysctl.h:523:7: note: expanded from macro 'SYSCTL_ADD_INT'
int *__ptr = (ptr); \
if_ix.c:4396:3: error: incompatible pointer types initializing 'int *' with an expression of type 'uint64_t *' (aka 'unsigned long *') [-Werror,-Wincompatible-pointer-types]
SYSCTL_ADD_INT(ctx, queue_list, OID_AUTO, "lro_flushed",
2 errors generated.
*** Error code 1
Stop.
make: stopped in /root/ix-3.1.14/src
Is there any tool in FreeBSD like linux ethtool?
# ifconfig ix0 media 10000baseT
ifconfig: unknown media subtype: 10000baseT
Please help me.
Hi Jinsoo.suh
Thank you for the info. I don;t have the information about Freebsd as this is third party OS. I managed to search on web and found information below, you may want to check if this is applicable to you (please note this is a third party website for your reference only, we are not endorising this web content and have on control over the suggestion given).
http://www.cyberciti.biz/faq/howto-configure-freebsd-full-half-duplex-speed/
You may want to check with Freebsd support if there is equivalent ethtool.
thanks,
wb
진JinS
Intel provide ixgbe driver for FreeBSD.
https://downloadcenter.intel.com/download/14688/Network-Adapter-Driver-for-PCI-E-10-Gigabit-Network-Connections-under-FreeBSD- Download Network Adapter Driver for PCI-E* 10 Gigabit Network Connections under FreeBSD*
What is media subtype for 10Gbps?
Hi Jinsoosuh,
I will check on this, but have you tried also the driver provided by Supermicro* on the sourceforge site?
https://sourceforge.net/projects/e1000/files/ixgbe%2520stable/ https://sourceforge.net/projects/e1000/files/ixgbe%20stable/
As mentioned the driver support is limited.
rgds,
wb
진JinS
Hi wb,
The driver on the sourceforge site is for Linux not for FreeBSD.
HI Jinsoosuh,
Thank you for the information. The Freebsd 3.1.14 you downloaded from Intel website does not support X552/557 series.
https://downloadcenter.intel.com/download/14688/Network-Adapter-Driver-for-PCI-E-10-Gigabit-Network-Connections-under-FreeBSD-?product=59787 Download Network Adapter Driver for PCI-E* 10 Gigabit Network Connections under FreeBSD*
rgds,
wb
Hi JinSooSuh,
Good day. Please try to connect the NIC to other switch brand to isolate the issue.
Do let me know the test result.
wb
진JinS
Dear wb,
The Supermicro tech. support team informed me that they tested on their https://www.supermicro.com.tw/products/accessories/Networking/SSE-X3348S.cfm SSE-X3348SR switch.
I will try your suggestion. But at this moment, I couldn't locate other switch brand.
Hi JinSoo.Suh,
Thank you for the update. Please do let me know the test results of testing on other switch when you or Supermicros had done the test.
wb
진JinS
Dear wb,
In my Linux case with Supermicro X10SDV-4C-TLN4F and HPE 1950 24G 2SFP+ 2XGT Switch,
following two methods make both intefaces are up with 10Gbps.
= Increase the interface MTU value to 9216(HP 1950 series default and maximum value)
# ifconfig eno3 mtu 9216
# ifconfig eno4 mtu 9216
= Set the interface to advertise only 10000baseT Full in autonegotiation.
# ethtool -s eno4 advertise 0x1000
But in FreeBSD, increasing only mtu values did not make intefaces are up with 10Gbps.
Do you Intel have plan for updating FreeBSD driver for X552/X557?
Hi JinSooSub,
Thank you for the update. I do not have information about the driver yet. Let me check for you.
rgds,
wb
진JinS
Dear wb,
Extreme Summit X670V-48t was temporarily available and I connected it to X10SDV-4C-TLN4F.
They autonegotiated to 10Gbps as expected.
Hi JinSoo.Suh,
Thank you for sharing the information. Good to know it work on the Extreme Summit X670V switch
rgds,
wb
진JinS
Hi wb,
I also tested Netgear models.
Here are test results.
Model: port used, link speed
HPE http://www8.hp.com/us/en/products/networking-switches/product-detail.html?oid=6887535 1950 24G 2XFP+ 2XGT (JG960A): 10GBase-T uplink port, sometimes 1Gbps, sometime 10Gbps, mostly 1Gbps, rebooting or cable unplug/plug
Netgear http://www.netgear.com/business/products/switches/smart/S3300-28X.aspx# tab-techspecs S3300-28X (GS728TX): 10GBase-T uplink port, sometimes 1Gbps, sometime 10Gbps, mostly 1Gbps, rebooting or cable unplug/plug
Netgear http://www.netgear.com/business/products/switches/smart/S3300-52X.aspx# tab-techspecs S3300-52X (GS752TX): 10GBase-T uplink port, sometimes 1Gbps, sometime 10Gbps, mostly 1Gbps, rebooting or cable unplug/plug
Netgear http://www.netgear.com/business/products/switches/managed/M4300-28G.aspx# tab-techspecs M4300-28G (GSM4228S): 10GBase-T uplink port, 10Gbps
Extreme Networks Summit http://www.extremenetworks.com/product/x670-series/ X670V-48t: 10GBase-T port, 10Gbps
Netgear M4300 series are more expensive than Netgear S3300 series and HPE 1950 series.
It seems Intel 10Gbase-T NICs are not compatible to low price switch models.
rgds,
ssoo
Hi Jin soo. Suh,
Thank you very much for taking time to test and sharing the test result. The is no issue when connecting the X550 to Netgear M4300 or Netgear XS712T. We will further check on this.
thanks,
wb
Hi JinSoo.Suh,
Good day. X550/X552 does supports Freebsd driver version 3.1.14 and is available at
However, the network adapter is still not listed on the website.
wb
진JinS
Hi wb,
I omitted OS & Driver version information from the test results.
This is not a OS or driver problem but hardware problem.
= Motherboard: Supermicro https://www.supermicro.com.tw/products/motherboard/Xeon/D/X10SDV-4C-TLN4F.cfm X10SDV-4C-TNL4F
- LAN: 2x 1GBase-T via Intel i350-AM2, 2x 10GBase-T via SoC(Xeon D-1518)
= OS Version, Driver Version
CentOS 7.2, ixgbe-4.3.15
FreeBSD 10.3, ix-3.1.14
FreeBSD 11.0-RC3, ix-3.1.13-k
= Switch Model: port used, link speed
HPE http://www8.hp.com/us/en/products/networking-switches/product-detail.html%3Foid%3D6887535 1950 24G 2XFP+ 2XGT (JG960A): 10GBase-T uplink port, sometimes 1Gbps, sometime 10Gbps, mostly 1Gbps, rebooting or cable unplug/plug
Netgear http://www.netgear.com/business/products/switches/smart/S3300-28X.aspx%23tab-techspecs S3300-28X (GS728TX): 10GBase-T uplink port, sometimes 1Gbps, sometime 10Gbps, mostly 1Gbps, rebooting or cable unplug/plug
Netgear http://www.netgear.com/business/products/switches/smart/S3300-52X.aspx%23tab-techspecs S3300-52X (GS752TX): 10GBase-T uplink port, sometimes 1Gbps, sometime 10Gbps, mostly 1Gbps, rebooting or cable unplug/plug
Netgear http://www.netgear.com/business/products/switches/managed/M4300-28G.aspx%23tab-techspecs M4300-28G (GSM4228S): 10GBase-T uplink port, 10Gbps
ssoo
Hi JinSoo.Suh,
Thank you for the additional test done. Have you tried using back-to-back connection to test the speed of our Intel adapter adapter just to isolate if this might be compatibility issue on the switch.
rgds,
wb
