Ethernet Products
5291 Discussions
x710 - firmware update
SHers
Hi
I am trying to update firmware to my x710 card using linux and nvmupdate64e
But tools says that update is not available, am i doing something wrong ?
./nvmupdate64e -u -l -o update.xml -b -c nvmupdate.cfg
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.24.33.08
Copyright (C) 2013 - 2015 Intel Corporation.
Config file read.
No devices to update
Post update inventory
./nvmupdate64e
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [+.........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1572 02:00 Update not available
02) Intel(R) I350 Gigabit Network Connecti 8086-1521 06:00 Update not available
lspci -v | grep Eth
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Subsystem: Intel Corporation Ethernet Controller X710 for 10GbE SFP+
02:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X710
ethtool -i eth1
driver: i40e
version: 1.3.49
firmware-version: 4.26 0x80001609 0.0.0
bus-info: 0000:02:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
st4
New Contributor III
HI Szym,
What is the serial number of your X710 network adapter? You may check this website out on where to locate the serial number
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005584.html Identify Your Wired Ethernet Adapter and Driver Version for Network...
Ther serial number has the format of 5 digits + 6 digits + 6-3 digits
wb
SHers
lspci -nn | grep -i 'Ethernet Controller'
02:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
02:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
lspci -vv | grep -i 'Intel Corporation Ethernet Controller X710'
Capabilities: [e0] Vital Product Data
Product Name: Intel X710 2x10GbE SFP+ Adapter for IBM System x
Read-only fields:
[SN] Serial number: 11S81Y3521Y050KK53M01U
[PN] Part number: 81Y3520
[MN] Manufacture ID: 30 30 30 41
[V1] Vendor specific: Intel X710 2x10GbE SFP+ Adapter for IBM System x
[V2] Vendor specific: 81Y3521
[VL] Vendor specific: 81Y3522
[VR] Vendor specific: 22
[VS] Vendor specific: 32773
[VT] Vendor specific: 9
[EC] Engineering changes: N33474
[VU] Vendor specific: 43DD395ED4DA445E8E5C86DFD2674DFD
[RV] Reserved: checksum good, 0 byte(s) reserved
SHers
OK i see that is "Adapter for IBM System x" but was sold as Intel
trying intc_sw_nic_v20.3-cd_anyos_32-64.iso without success (firmware 4.50)
intc_sw_nic_v20.0-cd_anyos_32-64.iso (4.42) worked fine
SHers
Trying to upgrade frmware 4.50 shows:
Error: Image iSCSI offset exceeds image size (offset=0x663, image size=0x200)
st4
New Contributor III
Hi Szym,
Thank you for the updaet. Try to get the firmware from IBM, the available firmware on our website is here https://downloadcenter.intel.com/download/24769/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-X710-Series?wapkw=x710 Download NVM Update Utility for Intel® Ethernet Converged Network Adapter XL710 & X710 Series but it is recommended to uset he OEM version if you are using an OEM NIC.
rgds
wb
SHers
ok thanks
Can you give me 'trick' to force update to intels firmware ?
