Ethernet Products
5821 Discussions
x710 firmware update
YDeng4
I have trouble updating firmware for X710DA4 card.
This card drops connection at random with Linux 4.9.9 driver.
The driver requires firmware update. But I tried all three versions
at Intel website and all said update not available.
Any help would be much appreciated.
ethtool -i ens4f1
driver: i40e
version: 2.0.19
firmware-version: 4.10 0x800011c5 0.0.0
expansion-rom-version:
bus-info: 0000:02:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
lspci does not show serial number:
Capabilities: [e0] Vital Product Data
Product Name: XL710 40GbE Controller
Read-only fields:
[PN] Part number:
[EC] Engineering changes:
[FG] Unknown:
[LC] Unknown:
[MN] Manufacture ID:
[PG] Unknown:
[SN] Serial number:
[V0] Vendor specific:
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[V1] Vendor specific:
End
Hi uqing,
Thank you for posting in Wired Ethernet Community.
Kindly share the markings of your X710 and brand/model of module installed for us to further investigation your issue.
The markings is found in the white barcode label of your X710.
regards,
Vince
YDeng4
Thanks for your reply, Vince.
I can only find this number on the card:
6805CA280888 22407 H34308-003
Hi uqing, I've sent you private message.
regards,
Vince
Hi Yuqing, Thanks for your reply, normally, for retail X710, it would have yottamark sticker at the adapter's back side. Sharing the sample yottamark sticker found in this website - http://www.intel.com/content/www/us/en/support/network-and-i-o/000007074.html Yottamark* Sticker on Intel® Ethernet Adapters . Have you tried running this command to update your X710 FW?
./nvmupdate64e -u -l -o update.xml -b -c nvmupdate.cfg
Please also try out this command to show details of your X710
lspci -vv | grep -i 'Intel Corporation Ethernet Controller X710'
regards,
Vince
Hi Yuqing,
We'd like to follow-up the requested details. These will help us in our issue resolution.
regards,
Vince
