我在使用intel三速以太网IP核时,按照用户手册编写了MAC的配置模块,UDP发送模块和UDP接收模块,目前的发送模块已经测试成功,但是接收模块出现了问题,就是接收模块在对MAC的用户侧(ff_rx_data)数据解析时不成功,为了分析原因,用quartus II中的SignalTap抓取SignalTap抓取ff_rx_data信号,发现数据包的头部少了一个字节,导致了后面所有的数据错位。使用的100M模式,MAC选项只勾选了Align packet headers
to 32-bit boundary其余的均没有使用,FIFO选项:TX和RX均使用的是1024*32bit。请教一下是我的配置有什么问题吗,怎么改就一直是这种现象
Can you elaborate further on your problem statement "header of the data packet was one byte less" ?
- Is your payload data corrupted ?
- Or payload data shifted with extra zero padding bits ?
- It would be best if you can circle or highlight the problematic data in your signal_tap result
As for the TSE IP MAC option with "Align packet headers to 32-bit boundaries" enabled.
- TSE MAC IP will auto pad extra 2 bytes of zero data at the beginning of Ethernet Frame.
- Looking at your signal tap result with starting received data of 0000FFFFh. This looks correct and expected result. Correct me if I am wrong.
- You can refer to TSE user guide doc (page 43, chapter 4.1.4.9. IP Payload Alignment) for more detail
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
You can always disable the ""Align packet headers to 32-bit boundaries" if it affect your data result alignment.
dlim
非常感谢您的回复!
我把我的问题详细描述一下,就是我用电脑的网络调试工具向FPGA发送一个UDP数据包,以广播的方式发送,MAC接收路径的用户侧应该接收到这样的数据 0000FFFF FFFFFFFF 000EC6C2 5DE00080 + 有效数据载荷。
使能了Align packet headers to 32-bit boundary,所以前面添加了两字节的0,紧跟着的6个字节是目的MAC地址(广播帧:6字节的ff),在跟着的是源MAC地址也就是电脑网卡的地址和协议类型(ip协议0800)。
出现问题的地方就是在目的mac地址得到这6个字节,从singaltap抓取到的数据来看是少了一个字节的ff,不知我现在是否已经描述清楚,方框中的数据是出现错误的地方,麻烦您再帮我指教一下,谢谢您!
非常感谢您的回复!
Thanks. I understand your problem statement now.
- You are sending broadcast address FF:FF:FF FF:FF:FF
- But Signal_Tap only captured FF:FF:FF FF:FF, looks like last 2 bytes of FF is missing
Couple debug suggestion
- Align packet headers to 32-bit boundary is enabled
- Align packet headers to 32-bit boundary is disabled
- Have you enabled TSE IP statistic counter option and read on register (Dword Offset 0x18 – 0x38) to check on potential error ?
- Did you also monitor TSE IP "status LED signals" to check for potential error ?
- Do you observed TSE RX FIFO underflow or overflow issue ?
- Do you still see similar issue when sending unicast address instead of broadcast address ?
- Do you still see similar issue when sending TCP/IP instead of UDP packet ?
- Lastly, would you be able to perform TSE IP internal loopback testing to isolate external factor issue ?
- ff_tx -> TSE MAC -> ff_rx
dlim
您好!
再次感谢您的回复,我在您给的建议下做了如下的测试:
1.使用了本地回环模式即TX->TSE MAC->RX,这个现象依然存在,FIFO端口用的32bit
2.在FIFO宽度设置为8bit的模式下使用本地回环,依然还有这种现象。
3.没有发单播数据报和TCP/IP报,因为我的调试软件在没有知道TSE MAC的MAC地址时不能发送单播报文。
4.FIFO用32bit,不采用Align packet headers to 32-bit boundary ,也有这种现象。
我把我的工程发给您一下。
软件版本是Quartus II13.0 SP1(64bit)
再次非常感谢
HI,
Sorry, I sent the message without completing below update.
- Did you configure register "tx_cmd_stat" and "rx_cmd_stat" correctly as your earlier screen shot shown "comment out" ?
- Just for debug purpose to see if it helps
dlim
HI,
Sorry for the late reply. I have some questions after reviewing your design.
I ahve
dlim
HI,
Sorry, I meant I have sent you private message.
dlim
HI,
I haven't hear back from you in the private message.
Do you had an chance to review my comment in the private message ?
dlim
你好!
我很抱歉没有及时回复您的邮件!
由于前段时间网络的原因,导致我没有登录进支持社区,所以后面就一直没有回复。
现在我的项目接收路径没有用TSE MAC,我自己写了模块对PHY的数据进行解析,可以实现我需要的功能了。
等这段时间忙完了再来解决这个问题。
再次非常感谢您!
HI,
No problem. It's good to know you are able to proceed with your project development.
Alright, for now I am setting this case to closure first.
Feel free to file new forum thread if you still face issue in future.
dlim
