Hi all,
I am working on a board that will use the 10G Ethernet in the Arria 10AX057K2F40I1HG part.
Is there a "best" pinout for the pins used for the 10G Ethernet port?
Cheers,
Rolf
All transceiver channel is designed with equal performance.
We only differential the Arria 10 transceiver channel by type and not by transceiver pin location.
- GX transceiver channel can meet certain performance
- GT transceiver channel can meet certain performance
- Detail to be found in Arria 10 datasheet
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_datasheet.p...
Using Gx transceiver channel is sufficient for 10G application
dlim
hi @Rolf_2 ,
Don't know where your 10GE card is plugged in, but I just have a question
“ do you know which host driver is used for 10GE Arria10 from host point of view ? (maybe in linux OS) ?
Thanks in advance~
