FPGA Intellectual Property
6670 Discussions
10G-BASER PHY High bit error rate
Hi All,
I am trying to bring up 10 GBASER PHY in Stratix V FPGA. After setting up the Design based on the reference design provided I am still having trouble with my hi_ber signal. It still remains high while the block lock signal remains high. Kindly give more insights as to the best debug steps for this problem.
Hello Sir,
do you set good assigment to?:
XCVR_TX_SLEW_RATE_CTRL
XCVR_TX_PRE_EMP_1ST_POST_TAP
XCVR_TX_VOD
OUTPUT_TERMINATION
INPUT_TERMINATION
XCVR_RX_LINEAR_EQUALIZER_CONTROL
INPUT_TERMINATION
