FPGA Intellectual Property
6514 Discussions
10G Ethernet IP on Cyclone 10 GX with IEEE 1588 support - Ordering Guide
CNiclaes
I would like to integrate a 10G MAC + 10G PHY with support for IEEE 1588.
For the PHY, the IP to be purchased seams to be IP-10GMRPHY. Is it correct?
For the MAC:
Question 1: Do I need to purchase both IP-10GEUMAC and IP-10GEUMACF or is IP-10GEUMAC integrated into IP-10GEUMACF license?
Question 2: When I compile my design in evaluation mode I get "Evaluation Mode" messages for 3 IPs:
IP-10GMRPHY
IP-10GETHMACF
Low Latency Ethernet 10G MAC
Which IP block is integrated in which license?
Thanks for support!
ShengN_Intel
Sorry for confusion. May check this link https://www.intel.com/content/www/us/en/products/details/fpga/intellectual-property/interface-protocols.html
IP-10GEUMAC is Low Latency 10 Gigabit Ethernet MAC
IP-10GEUMACF is Low Latency 10 Gbps Ethernet MAC with 1588 option
Seems like you want to integrate a 10G MAC + 10G PHY with support for IEEE 1588, I think you need to purchase only IP-10GEUMACF
IP-10GMRPHY - 1G / 2.5G / 5G / 10G Multi-Rate Ethernet PHY
IP-10GETHMACF - 10Gbps Ethernet MAC with 1588
Low Latency Ethernet 10G MAC - IP-10GEUMAC
ShengN_Intel
Yes, you're correct.
For the MAC:
For Cyclone 10 GX, you just need IP-10GEUMAC. IP-10GEUMACF is for F-Tile Low Latency Ethernet 10G MAC Intel® FPGA IP for the Agilex™ 7 (F-Tile) devices
IP-10GMRPHY - 10Gb Ethernet PHY Intel® FPGA IP
IP-10GETHMACF - F-Tile Low Latency Ethernet 10G MAC Intel® FPGA IP
Low Latency Ethernet 10G MAC - Low Latency Ethernet 10G MAC Intel® FPGA IP
Sheng
CNiclaes
I don't understand your answer related to the F-Tile for Agilex. I'm compiling the MAC with IEEE 1588 for Cyclone 10 and I get a licensing message concerning the IP-10GETHMACF, so it's mandatory for this feature on Cyclone 10?
Christophe
ShengN_Intel
