Hello.
I am wonder if it is possible to pass EMIF RAM calibration on Arria 10 FPGA for 2S2Rx8 ECC memory using non-3DS type like 2Rx8 RDIMM ECC. I know that Arria 10 doesn't support 3DS memories, but the only difference seems to be in Chip ID signal (C0...C2). Therefore, can I overcome this restriction or 3DS memories use different calibration algorithms?
Memory sample used for tests: Micron MTA72ASS8G72PSZ-2S6.
Mark
Hi Mark,
"Is it possible to implement own hard memory controller in Quartus project? Or it is a part of hardware specification for FPGA?"
- Yes you can implement your own memory controller as soft memory controller with hard PHY.
- In the General tab of EMIF IP, there is a configuration option that allow you to choose a Hard PHY and Hard Memory Controller.
- Somehow it's depends on memory standard as well.
Adzim
Hi Mark,
Thank you for your question.
As you well known that the Arria 10 DDR4 does not support 3DS memory.
I already check with engineering regarding this matter and they have feedback with below point.
- This is due to the Arria 10 does not have support for the Chip ID bits required.
- Plus the hard memory controller does not support 3DS and the Chip ID bits.
Adzim
Hello Adzim,
I do have a follow-up question. Is it possible to implement own hard memory controller in Quartus project? Or it is a part of hardware specification for FPGA?
Mark
Hi Mark,
Adzim
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
