Hey,
I'm using the Reference design Generic Serial Flash Interface IP on Quartus Prime 18.1 to access Micron MT25QL512Mb flash memory.
Via NIOS processor, I'm trying to write data to this flash unsuccessfully.
I do it in this order:
1)Entering Quad SPI mode (by enter_quad_mode function).
2)Entering to 4-Byte addressing mode (by enter_4byte_addressing_mode function).
3) Enabling the writing (by write_enable function).
4)Writing the data (by write_memory_quad function)
5) Reading the written data (by read_memory_quad function)
these are the functions:
1) void enter_quad_mode()
{ IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x7,0x00000035);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x9,0x00000000);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x8,0x1);
2) void enter_4byte_addressing_mode()
{ IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x7,0x000000B7);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0xA,1);
3) void write_enable()
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x7,0x00000006);
4) void write_memory_quad()
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x4,0x00022222);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x0,0x101);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x6,7012);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_MEM_BASE,0x00000000,0xAA550000);
5) int read_memory_quad()
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x0,0x00000101);
IOWR(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_CSR_BASE,0x5,0x00000A0C);
return IORD(INTEL_GENERIC_SERIAL_FLASH_INTERFACE_TOP_0_AVL_MEM_BASE,0x00000000);
I'm using the function usleep(1000000) between each function I'm operating.
The received data (after I'm using the read_memory_quad function) is 0 instead of 0xAA550000.
this is the Device's datasheet (page 37):
I would like to get some help here,
Can you help me please?
Did you use this design?:
If not could you re-try using the above design, and let me know if the same issue occurs\.
Not sure if you have update on this? Kindly expect some late reply as the owner is taking some leave until next week.
Any update from your side?
