Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
ALT PLL Megawizard aborts
in qsys ALTPLL component aborts at starting.the component flashes in to qsys and then disappears.
I used it properly till yesterday.all of a sudden, ALT PLL is not opening in qsys. i tried re installing quartus subscription package.still it remains the same.
which quartus version?
Highlighted
There may be a problem with your project. Try creating a new blank project and see if you can use the ALTPLL component. If you can, you might try re-creating your project. It might also be caused by files in one of the .quartus directories in your home folder. I'm not sure how to fix these.
Highlighted
quartus 13.1
Highlighted
No.I tried creating a new blank project.still altpll cant be used.it just blinks and disappears.
Highlighted
You should make a service call to Altera for help with this. There are some other things you might try but I hesitate to recommend them because they might break your installation.
