FPGA Intellectual Property
6670 Discussions
ALTFP_CONVERT in Modelsim
I'm currently using the ALTFP_CONVERT megafunction in my design to convert a 10 bit integer to a 32bit FP. It has a clk_en (convert_en) and an aclr port (convert_rst).
Unfortunatly the output stays at high impedance (as shown in the attachment).
I get the following warning during the simulation setup:
--- Quote Start ---
# ** Warning: (vsim-8607) c:/altera/11.1/modelsim_ase/win32aloem/../altera/verilog/src/cycloneiii_atoms.v(6155): Non-positive replication multiplier inside concat. Replication will be ignored.
--- Quote End ---
which I don't really understand at all. Could that be related? Or is there something else I'm missing? Thanks in advance :)
You are not showing the output port of the altfp_convert megafunction. I don't think, that the output of altfp_convert is tri-stateable, apparently it's sourced from a register.
It's also not clear, if the warning is generated during processing of the MegaFunction or other parts of your design.
Thank you for your reply.
The section of my testbench for stimulating the convertor:
--- Quote Start ---
//Convert signals
logic convert_rst;
logic convert_en;
logic[9:0] in;
logic [31:0] out;
//Module
fpconvert converter(convert_rst,CLOCK_50,convert_en,in,out);
//Convert Signals
initial
begin
convert_rst = 1'b0;
convert_en = 1'b0;
in = 10'b0000000001;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
in = 10'b0000100001;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
# 50ns;
convert_rst = 1'b0;
convert_en = 1'b1;
end
--- Quote End ---
As you can see, it is the megafunction output port which is high Z.
I tried simulating without the 'mains' module (which is my entire design) which removed the 'Non-positive replication multiplier inside concat' error. So from what I can tell, it's a either an issue with the Megafunction or Modelsim.
Problem solved. I made a new copy of ALTFP_CONVERT with a different name and that seemed to fix it. Surprising how changing the name of a module seems to fix things... I have a feeling I may have made an incorrect port assignment in another module, which messed up the synthesis of ALTFP_CONVERT when I tried testing it by itself in modelsim.
Thank you for your help :)
