FPGA Intellectual Property
6450 Discussions
ALTFP_MULT and ALTFP_ADD_SUB issues
Hi there,
When I simulate the ALTFP_MULT and ALTFP_ADD_SUB megafunctions in modelsim (directly from my testbench, not through my main design) I get zero results from both. Has anyone else encountered this, or perhaps have any ideas why this might be happening?
I'm using this code to simulate them:
--- Quote Start ---
FIRadd addtest(
add_rst,
add_en,
CLOCK_50,
dataa,
datab,
add_result
initial
begin
add_rst = 1'b1;
add_en = 1'b0;
dataa = 32'h00000000;
datab = 32'h00000000;
# 50ns;
add_rst = 1'b0;
add_en = 1'b1;
dataa = 32'h0000000F;
datab = 32'h0000F001;
end
--- Quote End ---
Solved - parts of these megafunctions were being synthesised away, as the registers driving them (in my actual design) weren't driving them properly.
jacki2ya, I am having the same problem and you wrote here as solved but I could not understand how you solved. Please, could you write how you solve it?
My fix was fairly design specific. That is, I fixed a part of my design that drove these units and then they started synthesising properly.
As it was a little while back, the most I remember it being was that the registers that drove my ALTFP_MULT (which then fed the adders) were incorrectly specified. Once I fixed this small issue, everything else fell into place.
I wish I could give more information then that. I wish you the best of luck though, I know how frustrating it is!
Thank you jacki2ya. My problem was the same as yours. I solved it as well. Thanks.
