FPGA Intellectual Property
6605 Discussions
AXI - Without Write channels as a Qsys component
I have an AXI component that only needs to read so it does not implement the AXI write channels. Using the component editor in Qsys this gives errors.
Any way around this? I guess I can create dummy AXI Write channel signals and tie off the outputs and not connect the inputs.
What kind of errors?
--- Quote Start ---
--- Quote End ---
Hello Steve,
Qsys says it is missing the address write and write data channels. It's perfectly legal to create an AXI component that just writes or just reads. So this should not be an error.
I added the address write and write signals and tied off the outputs driving the rest of the AXI interconnect.
Cheers,
Tom
Hi, Tom!
You say it was the Component Editor that gave errors or Qsys when you tried to use the component? Very strange.
Yes the component editor gave the errors.
