FPGA Intellectual Property
6535 Discussions
Abnormal termination at Quartus IP generation. Do you know the environment, conditions or causes? Quartus_Ver. Prime Lite 18.0 Device Cyclone V 5CEFA7F31I7N IP DDR3 SDRAM controller with UniPHY Intel FPGA IP
ESasa
NurAida_A_Intel
Hi Sir,
Are you using windows 10? We receive few similar complain issue from other customer before. But we are unable to duplicate the same problem under our environment. Thus, it is hard to provide an accurate solution to customer because the issue is usually depend on customer PC environment.
My suggestion is :
1) Try different type of OS
2) Try this KDB solution:  https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd02192013_986.html
Hope this helps.
NAli1
