FPGA Intellectual Property
6619 Discussions
About DP and HDMI IP,do they support 240HZ?such as 1080P@240hz
EZhan
Deshi_Intel
HI,
Short answer is YES for both DP and HDMI IP.
One thing to take note is you should also consider the video resolution besides just the refresh rate.
Both DP and HDMI wiki page table clearly stated the design requirement
For instance using 1080p @ 240hz as example.
  • DP wiki page table mentioned it need HBR2. Our Intel DP IP does support HBR2, so no problem
  • HDMI wiki page table mentioned it needs HDMI 2.0 spec . Our Intel HDMI IP does support HDMI 2.0 spec, so no problem
I hope I clear your doubt. Thanks.
dlim
Deshi_Intel
HI,
I have not hear back from you. I hope my earlier feedback is helpful to you.
For now I am setting this case to closure.
dlim
