Hi all,
I am trying to run the dp_demo on my own board with dp tx & rx.
Following the software steps, I find it stopped at the function
btc_dptx_syslib_init();
with no any error/warning, no any debug info printted.
I can't find any c source file like btc_dptx_common.c/btc_dptx_aux_ch.c ... called by btc_dptx_syslib_init().
I am using the evaluation dp ip core/quartus prime 18.0.
The questions are:
1) When the function btc_dptx_syslib_init() give noting feedback, how to fix it?
2)How can I get the c source file like btc_dptx_common.c/btc_dptx_aux_ch.c etc...
Could someone please help with this, Thanks in advance!!!
Best Regards
Clark
Hi Clark,
Ideally all the DP IP core design should file should be stored in intelFPGA_pro\18.0_b219\ip\altera\altera_dp
For your case, maybe you can generate DP IP example design and compare with your own design.
Hi Clark,
想問你的問題獲得解答了嗎?
我最近也遇到了一樣的問題
