FPGA Intellectual Property
6400 Discussions
About the power supply of cyclone10LP
M_Goto
hello,
I am using 10CL016 F484.
The power supply is used as follows.
VCCIO monotonically reaches 3.3V as shown in the attached figure (ch2).
VCCINT, VCCD_PLL, and VCCA also monotonically reach the target voltage.
However, only VCCIO drops to 2V for a moment after 2ms.
Is this behavior problematic?
If there is a problem, what is the impact?
VCCINT: 1.2V
VCCD_PLL: 1.2V
VCCA: 2.5V
VCCIO: 3.3V
best reguards
Goto
AminT_Intel
Hello Goto,
I understand you are concerned about the drop voltage value. May I know what IO standard are you using in your design?
Thank you.
M_Goto
Thank you for answering me.
IO standard is a Single-Ended I / O Standard Specifications.
My design uses 3.3-V LVTTL and 3.3-V LVCMOS.
best reguards
Goto
AminT_Intel
AminT_Intel
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
