FPGA Intellectual Property
6518 Discussions
Adding Avalon ST interface to TSE (triple speed ethernet)
Hi
What would be the best way to attach another streaming component to TSE, right now I have
CPU--SGDMA-TSE
I need to add another Avalon-ST (with packet support) between TSE and some user_logic, what would be the best way to do it.
I am thinking Avalon-ST Splitter and Avalon ST Mux should do the trick. Any ideas? anyone?
Yes it should work. You can also have a look at the nios ethernet offload example (http://www.nioswiki.com/index.php?title=exampledesigns/nios2udpoffloadexample) on the Nios wiki, they are doing something similar.
You could build a "stream copying" module by yourself and put it in SOPC Builder. It simply connects the input ST interface to two output ST interface, one for the user_logic, the other for SGDMA.
