Dear all,
I need to make transfers PC-FPGA based system and need to select a bus for industrial environment. I was considering to use 10 Gpbs Ethernet or 3.0 USB but I am not sure this is the best way. Optical links can be the solution but I never used this kind of links. By the way I would like to solve the problem with an IP ready for SOPC. I never purchased an IP and I don´t know the price range of it. What do you think about? Any idea about the price range of an IP for such this transfer speed rate? Thank you very muchLink Copied
This is gonna be expensive, because at some point you need to use a protocols that PC use and that will require some expensive IP
AFAIK, here are your more realistic options. 1. 10 GbE. You'll need an off-the-shelf 10 GbE card and a 10 GbE core. However, the PC's CPU may have trouble with keeping up with raw 10 GbE (too many small packets) and you may need to add a TCP/IP core in the FPGA to take advantage of the TCP Offload Engine that the 10 GbE card will certainly have. 2. Infinband Like 10 GbE, you'll need a off-the-shelf Infiniband card and a Infiniband IP. Unlike 10 GbE, you won't need a TCP/IP core or nothing of the sorts. Be carefull: Infiniband's interoperability between diferent OEMs isn't always the best. 3. PCIe over fiber There are -- although I can't find the links right now -- some PCIe over fiber-optic bridges. You'll need a couple of those off-the-shelf bridges and a PCIe IP core. This will make your FPGA look like it's directly connected to the PC's PCIe tree. Not terribly sure this is a good idea though! 4. SeriaLite II Since there aren't -- AFAIK -- off-the-shelf SeriaLite II cards, you'll need a PCIe FPGA devkit with optical links, SeriaLite II IP core and a PCI/PCI-X/PCIe IP core. Despite requiring 2 IP cores, it may be the best option. I'm not terribly familiar with prices but 10-20K USD, maybe more. But you'll need to contact an Altera representative for that.- Mark as New
Thank you very much for the quick answer.
I´m starting to panic as far as I only can spend 6k on IP cores... What do you think about USB 3.0?- Mark as New
Might be a good option as well, but I'm not familiar with it.
You may (or not) have problems getting the full 3.6 Gbit/s out of USB 3.0. In any case, I might be a bit off in regard for prices, so try and get some quotes before you panic. :) BTW, some of Xilinx's Virtex5 and Virtex6 include a PCIe 1.1 endpoint for free. Maybe these are more expensive FPGA than you were planning to use but you might want to check out prices for a Xilinx based solution as well. Xilinx's equivalent to SeriaLite II is Aurora.- Mark as New
You can use PCIe embedded core and low cost FPGA to communicate using PCIe over fiber at 2.5 Gb/s (205 MB/s device to PC benchmark) or 5 Gb/s using PCIe Gen2 (Stratix-IV).
Using multiple PCIe lanes you can communicate over fiber optic up to x4/x8 lanes. To do so you need a Host controller similar to Adnaco-H1 and just place fiber optic transceivers on your board similar to Adnaco-RFPGA Coming soon an Adnaco-H1A which support PCIe Gen2 (5 Gb/s) industrial temperature grade and Adnaco-H2 for x4 lanes. Details you can find on adnaco web site. Sergej
