FPGA Intellectual Property
6673 Discussions
Altera Remote updater Cyclone V
I am triying to use the remote updater block from Altera. When I setup it (PAGE select, AnF bit, watchdog) and set the signal reconfig to '1', the FPGA does not do anything
-I setup the page, the AnF register, the watchdog value and Watchdog enable, and then I setup to one the reconfig signal and it does not do anything.
-The clk input freq is 10Mhz
-I check the status register (000) at the beginning after reset and the 5 bits are in '1' value ( all error), i check it later and it does not change.
-If i read the registers that i write (watchdog for example) appear to have a right value.
-The eeprom is EPCQ128
-Quartus 14.1
Could you give me any advice to make it work?
Is it possible for you to share your design? I will see if I can help you. In past, we successfully used Remote Status update block for Cyclone IV device.
Cheers,
Bhaumik
Its impossible to share the design, company rights.
One detail that i forgot was that it is implementid in a qsys system with NIOS II
--- Quote Start ---
--- Quote End ---
I update a screen after reset and then i read the status register.
--- Quote Start ---
--- Quote End ---
Ok. No problem.
We followed steps similar to provided in http://www.altera.com/literature/an/an603.pdf
Cheers,
Bhaumik
