FPGA Intellectual Property
6115 Discussions
Altera VIP simulation and the ref. design no.427
Hi, I'm new here. Glad to meet you.
I have 2 question about the latest (ver.8.0) of the Altera VIP (Video & Image Processing Suite)
1) Is there anyone here successfully simulating the VIP functions?.
The MegaCore wizard does not generate simulation models, test bench etc. I have to see if the VIP functions before implementing it on the hardware. Please advice!
2) Is there anyone successfully implementing (to generate SOF file) the ref. design for the VIP ver.8.0 as described in the app. note no.427 <http://www.altera.co.jp/literature/an/an427.pdf
When I tried to 'Start Compilation' (after re-generating the Nios-2 system using SOPC builder), the Quartus II stopped with 12 errors and hundreds of warnings. I am wondering if the ref. design really function.... Please advice!
Thanks in advance!
----------errors--------------------
Error: Node instance "my_alt_vip_clip" instantiates undefined entity "alt_vip_clip_GNVO2UKTWW"
Error: Node instance "my_alt_vip_cpr" instantiates undefined entity "alt_vip_cpr_GNJQ4YFLPE"
Error: Node instance "my_alt_vip_cpr_1" instantiates undefined entity "alt_vip_cpr_GNRW3PSMJV"
Error: Node instance "my_alt_vip_crs" instantiates undefined entity "alt_vip_crs_GNE6NPS5F5"
Error: Node instance "my_alt_vip_csc" instantiates undefined entity "alt_vip_csc_GNOSDMRPPF"
Error: Node instance "my_alt_vip_dil" instantiates undefined entity "alt_vip_dil_GNHDD6LS33"
Error: Node instance "my_alt_vip_mix" instantiates undefined entity "alt_vip_mix_GNWZPL24MV"
Error: Node instance "my_alt_vip_scl" instantiates undefined entity "alt_vip_scl_GNF4N44SOZ"
Error: Node instance "my_alt_vip_tpg" instantiates undefined entity "alt_vip_tpg_GNUAHFWJD4"
Error: Node instance "my_alt_vip_vfb" instantiates undefined entity "alt_vip_vfb_GNSVPB2QIW"
Error: Quartus II Analysis & Synthesis was unsuccessful. 10 errors, 83 warnings
Error: Peak virtual memory: 308 megabytes
Error: Processing ended: Fri Sep 26 07:10:29 2008
Error: Elapsed time: 00:04:19
Error: Total CPU time (on all processors): 00:00:53
Error: Quartus II Full Compilation was unsuccessful. 12 errors, 83 warnings
---------warnings-------------
Warning (10236): Verilog HDL Implicit Net warning at altmemddr_auk_ddr_hp_controller_wrapper.v(243): created implicit net for "mem_dqsn_en"
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(1124): object "ac_h_r" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(1125): object "ac_l_r" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(1126): object "ac_h_2r" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(1127): object "ac_l_2r" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(1134): object "ac_2x_retime" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(1135): object "ac_2x_retime_r" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(2325): object "global_reset_ams_n" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altmemddr_phy_alt_mem_phy_ciii.v(2326): object "global_reset_ams_n_r" assigned a value but never read
Warning: Variable or input pin "datad" is defined but never used
Warning: Assertion warning: oe input port is not connected
Warning (10034): Output port "wb_dat_o[31]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[30]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[29]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[28]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[27]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[26]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[25]" at opencores_i2c_master.vhd(16) has no driver
Warning (10034): Output port "wb_dat_o[24]" at opencores_i2c_master.vhd(16) has no driver
I am hoping you found a solution to this problem, as I am encountering the exact same error message.
William Guynes
It appears this error occurs if the user executing the Quartus II IDE does not have Administrator permissions.
Is it Altera's position that all FPGA developers have Administrator access? (to the local machine, not the domain)
If not, what sub-permissions must the developer account be granted in order to successfully compile?
