FPGA Intellectual Property
6543 Discussions
Alternate for 5CEFA4F23C8N
Donk1
New User
Hello Altera Team,
We're currently using Intel #5CEFA4F23C8N.
We are looking into the possibility of migrating to a slightly larger FPGA (same package), and I was wondering if there will be pinout issues: Intel #5CEFA5F23I7?
Thank you,
Don
FvM
The FPGA series is basically migration compatible, but some pins must stay unused or tied to GND/ supply in the design. There's a simple way to check if your present A4 pin assignment can be used with A5 as well,
1. add the migration device in Quartus and compile
2. compare the present pinout file with migration compatible pin mapping for additional GND and supply pin requirements.
Donk11
AqidAyman_Intel
Thank you @FvM for the accurate answer.
I wish to follow up if there is any additional question on this?
