FPGA Intellectual Property
6595 Discussions
Arria 10 PCIe Write DMA Descriptor Controller Registers
Ursa
Dear All,
I have a simple question but it is important to me and I didn't find an answer in the doc of ug_a10_pcie_avmm.
I think the WR_TABLE_SIZE register is allowed to change on the fly(not only in the initialization stage) by host driver, I just wanted to know if it can take effect at once after changing at anytime. Am I right?
Who can give me the answer yes or no? Thank you very much.
Ursa
Deshi_Intel
HI,
I don't think you can change it on the fly as I found below Note from the user guide doc
  • Because the DMA Descriptor Controller uses FIFOs to store descriptor table entries, you cannot reprogram the DMA Descriptor Controller once it begins the transfers specified in the descriptor table.
Detail in user guide doc (page 82)
dlim
Ursa
@Deshi_Intel Thanks Deshi,
Maybe my wording "on-the-fly" was not accurate, further ask, thus can I change this register in the gap time between two transfers? I just hope the entries of descriptor table can be dynamically changed in run time. Are there any methods?
Ursa
Deshi_Intel
HI,
If you are referring to "in between 2 transfer" then maybe it's still possible.
Anyway, I encourage you to test it out in hardware to be sure.
dlim
Deshi_Intel
HI,
It's been some time since I last heard from you. I hope you have find the answer by running test run to verify it
For now, I am setting this case to closure.
Feel free to post new forum thread if you still have enquiry in future.
dlim
