FPGA Intellectual Property
6659 Discusiones
Arria 10 PCIe pld_clk vs coreclkout_hip
lcy2000
Principiante
948 Vistas
Currently we have a project that has very tight latency requirement regarding PCIe. There's a 250Mhz clock driving most part of the design (let's call it user_clk). For PCIe HardIP, we follow the official example by directly connect coreclkout_hip to pld_clk. Thus, we need to run clock domain crossing in our design, which took roughly 5 cycles (20 ns) in simulation.
But recently I noticed the PCIe IP user guide mentioned that pld_clk can be driven other than coreclkout_hip .
So, I wonder if there's a already a CDC logic in Hard IP, regardless whether pld_clk is the same clock as coreclkout_hip. And we can save our cycles by connecting pld_clk to user_clk.
Thank you in advance for your help.
Chenyang
Etiquetas (1)
0 kudos
1 Solución
ventt
Empleados
788 Vistas
Hi Chenyang,
My apology for the delayed response.
Yes, according to the User Guide, the pld_clk, which is used to clock the Application and Transaction Layers, can be driven by a different clock than coreclkout_hip. Please take note of the requirements for pld_clk as stated in Section 7.2.2, Clock Summary Table 65.
For instance, if the chosen coreclkout_hip is 125 MHz and the pld_clk is sourced from another clock source, it must be equal to or greater than 125 MHz but have a maximum frequency of 250 MHz. In your case, it can be connected to a 250 MHz clock source (user_clk).
The PCIe Hard IP contains a CDC synchronizer at the interface between the PHY/MAC and the DLL layers to allow the DLL and Transaction layers to run at frequencies independent of the PHY/MAC.
Arria® 10 and Cyclone® 10 GX Avalon® Streaming Interface for PCI Express* User Guide: https://www.intel.com/content/www/us/en/docs/programmable/683647/18-0/clock-summary.html
Ven
Ver la solución en mensaje original publicado
7 Respuestas
ventt
Empleados
889 Vistas
Hi lcy2000,
Thanks for reaching out.
Allow me some time to investigate your issue. I shall come back to you with the findings.
Ven
lcy2000
Principiante
812 Vistas
Hi ventt,
Thank you for handling my case. Do you have any updates on this question?
Thank you very much ~~
Chenyang
ventt
Empleados
789 Vistas
Hi Chenyang,
Ven
ventt
Empleados
750 Vistas
Hi Chenyang,
Kindly take note that 31 Mar and 1 Apr 2025 are national public holidays, please expect a delay in response.
Ven
lcy2000
Principiante
717 Vistas
Hi ventt,
Sorry for delayed response lately. I've tested using `user_clk` to drive `pld_clk` and currently it works as expected.
Thank you twice for hanlding my case and happy Eid al-Fitr ~~
Chenyang
ventt
Empleados
649 Vistas
Hi Chenyang,
Thank you for the updates and your kind wishes!
Glad to hear that using the user_clk to drive pld_clk works for you.
I will transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Altera experts.
Ven
ventt
Empleados
496 Vistas
Hi Chenyang,
My apologies for missing your forum post.
Please allow me some time to investigate, and I will get back to you in 1-2 days.
Ven
Responder
