FPGA Intellectual Property
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
6317 Discussions
Arria II GX kit + SDI + VIP , only CVI->CVO, CVO no output
Arria II GX kit + SDI + VIP , only CVI->CVO, CVO no output.
There are is_clk,is_data,vid_clk,vid_data,vid_data_input,no av_readdata,av_writedata,is_active_line_count_f0,is_active_line_count_f1. Doesn't Avalon-MM work? how to deal with it? Main clock is 100M,CVI.control connect Avalon-MM Pipeline Bridge.Avalon Memory Mapped Slave.CVI.clock is 100M.
Who can help me?
Post the SOPC/QSys screenshot here.
Please check Qsys. To change util_bridge_1,sdi_in_1,sdi_out_1'clock from 100M to 150M,many signals can be looked using SignalTap II Logic.such as,u1_A2gxSDI3G|rx_video_format,rxdata,tx_std,txdata,sdi_in_1|is_clk,is_data,
is_valid,is_ready,sdi_out_1|is_clk,is_data,is_ready,is_valid,..etc. But there are no video output. If there are no Qsys,only using loopback, there are video output.
Please check Qsys.bmp.
CVI Parameters:
Bits per pixel per color plane:10bits
Number of color planes:2
Color plane transmission format:Paraller
Field order:Field 0 first
Sync signals:Embedded in video
Allow corlor planes in sequence input
use vid_std bus
width of vid_std bus: 3 bits
Extract ancillary packets
Interlaced
widh:1920 pixels
Height-frame/field 0:540
Height-field1:540
Pixel FIFO size:4000
use control port
Generate synchronization outputs:Yes
CVO Parameters:
image width/Active pixels: 1920
image height/Active lines:1080
Bits per pixel per color plane: 10
Allow output of channels in sequence
Interlaced video
Synces signals:Embedded in video
Active picture line:21
Ancillary packet insertion line:0
Horizontal blanking:280
Verticla blanking:22
Horizontal sync:0
horizontal front porch:0
Horizontal back porch:0
Vertical sync:0
Vertical front porch:0
Vertical back porch:0
F rising edge line:564
F falling edge line:1
Vertical blanking rising edge line:561
Ancillary packet insetion line:0
Vertica balnking:23
Vertical sync:0
verticl front porch:0
Pixel fifo size :1920
fifo level at which to start ouput:1919
use control port
Accept synchronization ouputs
Runtime configurable video modes:3
width of vid_std bus:3
using SignalTap,sopc_system:sopc_system_inst|alt_vipitc111_IS2Vid:sdi_out_1|vid_std = 0. The CVO doesn't work normally,is right?
The screenshot doesn't give any information, since You've not expanded all the modules and connections are not shown. E.g. now it shows that pipeline bridge slave is not connected.
vid_std shows video standard and has nothing to do with the stream itself.
Hi, Socrates,thank you very much for your reply.
I fixed the design in Qsys.The TPG connect to CVO directly, TPG and CVO no control. If no software control,normally it should be have output,is right? But my CVO no output.
TPG parameter is
Maximum image width:1920,Maximum image height:1080, Bits per pixel per color plane:10,
Colorspace:YCbCr,
Output format: 4:2:2
Color plane configuration: Parallel
Interlacing: Progressive output
Pattern: Color bars
The SDI is tested by loopback. It is OK. There are output.
From Qsys CVO only have the follows parameter:
.sdi_out_1_clocked_video_underflow(),
.sdi_out_1_clocked_video_vid_clk(tx_p2_pclk ),
.sdi_out_1_clocked_video_vid_data(sdi_tx_data_sopc),
.sdi_out_1_clocked_video_vid_ln(sdi_tx_ln_sopc),
.sdi_out_1_clocked_video_vid_trs(sdi_tx_trs_sopc)
A2gxSDI3G_ch4 u1_A2gxSDI3G (
//common
.rst_rx ( reset ), //input
.rst_tx ( reset ), //input
.sdi_gxb_powerdown ( 1'b0 ), //input
.gxb4_cal_clk ( gp_clk ), //input
//core config settings
.enable_ln ( enable_ln_p2 ), //input [0:0]
.enable_crc ( 1'b1 ), //input [0:0]
.en_sync_switch ( ), //input
.enable_hd_search ( 1'b1 ), //input
.enable_sd_search ( 1'b1 ), //input
.enable_3g_search ( 1'b1 ), //input
//tx inputs
.tx_pclk ( tx_p2_pclk ), //input - loopback clock
.tx_serial_refclk ( gxb_refclk ), //input - from pcie 148.5 vcxo
//.txdata ( fifo_data_p2 ), //input [19:0]
.txdata ( sdi_tx_data_sopc), //input [19:0]
.tx_trs ( sdi_tx_trs_sopc ), //input [0:0] - not used
.tx_ln ( {sdi_tx_ln_sopc,sdi_tx_ln_sopc} ), //input [21:0] - not used
//.tx_std_select_hd_sdn ( ), //input
//.tx_data_type_a_bn ( 1'b1 ), //input
//.tx_std (pclk_74),
//.tx_trs ( txtrs_p2 ), //input [0:0] - not used txtrs_p0
// .tx_ln ( {11'b0,txln_p2} ), //input [21:0] - not used {11'b0,txln_p0}
.tx_std ( tx_std_p2 ), // tx_std_p0
//tx outputs
.sdi_tx ( hsma_tx_p[0] ), //output [0:0]
.gxb_tx_clkout ( tx_p2_clkout ), //output [0:0]
.tx_status ( tx_p2_stat ), //output [0:0] - not used
//rx inputs
.rx_serial_refclk ( gxb_refclk ), //input
.sdi_rx ( hsma_rx_p[0] ), //input [0:0]
//rx outputs
//.rxdata ( sdi_rx_data), //output [19:0]
//.rx_data_valid_out (sdi_rx_data_valid_out ), //output [1:0]
.rxdata ( rx_p2_data ), //output [19:0]
.rx_data_valid_out ( rx_p2_data_valid ), //output [1:0]
.rx_clk ( rx_p2_clk ), //output -same as "port1_rx_clk"
.rx_status ( rx_p2_status ), //output [10:0]
.rx_ln ( rx_p2_ln ), //output [21:0]
.rx_std ( rx_p2_std ), //output [1:0]
//not used
.rx_anc_data ( rx_p2_anc_d ), //output [19:0]
.rx_anc_valid ( rx_p2_anc_v ), //output [3:0]
.rx_anc_error ( rx_p2_anc_er ), //output [3:0]
.rx_std_flag_hd_sdn ( sdi_rx_std_flag_hd_sdn_0 ), //output [0:0]
.rx_F ( rx_p2_F ), //output [1:0]
.rx_V ( rx_p2_V ), //output [1:0]
.rx_H ( rx_p2_H ), //output [1:0]
.rx_AP ( rx_p2_AP ), //output [1:0]
// reconfig inputs
.sdi_reconfig_clk ( sdi_reconfig_clk ), //input
.sdi_reconfig_togxb ( sdi_reconfig_togxb ), //input [3:0]
.sdi_reconfig_done ( multi_reconfig_done[0] ), //input
//reconfig outputs
.sdi_reconfig_fromgxb ( rc_fromgxb[16:0] ), //output 16 bits
.sdi_start_reconfig ( sdi_start_reconfig[0] ) //output
Why is it not output?
The CVO have output. I fixed the parameter of CVI and CVO according to Altera supported's suggestion. Thanks!
