使用10AX027和CPU调试PCIe时发现以下问题:
调试过程中软件驱动负责分配一块物理内存,然后把物理内存地址写入FPGA,FPGA从这个物理内存地址做DMA,读取内容。
在Xeon系列的硬件平台上的异常现象是:
当驱动分配的物理内存在4G以上时,FPGA做DMA是可以的,分配到4G以下时,FPGA发送tlp的读请求后,始终得不到响应,DMA失败。
做了以下尝试:
- 将FPGA及driver的DID和REV的register改掉,不为0x0000,DMA仍会失败。
- FPGA将内部逻辑改为32位地址的模式,没有作用。
- 当分配到4G以下的地址时,手动将高32位地址置1,DMA是可以的。
- CPU修改BIOS的设置,没有作用。
- 抓了AER数据,FPGA发送tlp的读请求后得不到响应时,没有抓到transpend+的数据。
但是在ATOM C2758,酷睿 I5上分配4G以下的地址时,DMA都是OK的。
客户是自己写的DMA程序,请问可以判断问题可能出在哪里吗?
谢谢
As per what I understand here, this is using a custom driver to run the DMA test, where if the address allocation from the host is less than 4G, the test will fail.
Do you test the an829 design before?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an829.pdf
What is the "address width of accessible PCIe memory space" setting in the design?
Regards -SK
Hi Nicole,
From the FPGA site, the PCIe is configured as AVST GEN2x4, then there is a custom module to connect the Avalon ST interface with the DMA? What is the memory size selected from the PCIe GUI's BAR tab?
When issue a memory write or read TLP from the Host, did you able to see the TLP appear at the Avalon ST interface?
If possible, please help to explain why is the DMA not working? Is this unable to receive the TLP from the Avalon ST interface of PCIe IP, or the PCIe IP sent incorrect packet to the DMA module in the FPGA?
Regards -SK
If the read request is sent out from the AVST to DMA. At this point, the PCIe IP still working fine. Do you mean the AVST interface does not receive the completion from the custom DMA? If yes, then this is required to debug from the DMA perspective.
Regards -SK
Hi Nicole,
Thank you for the clarification. I don't aware if there is a similar issue. At this point, it does not look like the PCIe AVST problem yet. The PCIe AVST is a hard block, it will pass the TLP that received from the host to the DMA.
From the AER, does it show the completion timeout or any other error? If yes, it means that the Host does not return the completion.
If the completion package does not observe from the AVST interface, then you might need to debug it by using a PCIe protocol analyzer to confirm if the host really sent a valid completion TLP to the endpoint (FPGA).
Regards -SK
For AER definition, you can refer to section 9.5:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avst.pdf
If you are using Linux, the command below might be helpful to read the AER:
setpci -s B:D.F ECAP_AER+0x10.l
setpci -s B:D.F ECAP_AER+0x04.l
Regards -SK
Yes, this is one of the debug item. Another thing is to capture the signal tap to confirm whether the PCIe HIP AVST interface did receive the completion TLP, this can help to understand whether the packet is missing.
Regards -SK
Please do let me know if you have an update or more help is needed here. Thanks.
Thank you.
I will set this case to close-pending for now. Please do not hesitate to get back to me within the next 20-day close-pending period if more help is needed.
Regards _SK
