FPGA Intellectual Property
6670 Discussions
Avalon-MM Master Read/Write Template
I'm using Altera's Avalon-MM Master Read/Write template.
The problem is, that the adress will not increment automatically.
For testing I wrote known data in the memory and verified them with NIOS2.
Reading the data with the template, manually incrementing the adress works fine, but I think this will be slower as I cannot use reasonably the fifo.
Configuration:
32bit adressbus
32bit databus
control_fixed_location=0
control_read_base=x"0c000000"
control_read_length=x"00000004";
for starting reading, I set control_go for one clock_cycle high.
for reading data, I clock the user_read_buffer input.
attached: signal-tap signals (corr_reader_clock=user_read_buffer)
Any ideas?
Best Regards
Mark
The address isn't incrementing because you are telling the master to move 4 bytes of data (one transfer and it's done). Typically you tell the master to move multiple words of data in sequential memory locations.
