FPGA Intellectual Property
6667 ディスカッション
Avalon ST Multiplexer -> is it possible to concatenate?
amildm
高評価コントリビューター I
1,859件の閲覧回数
As for the Avalon ST Multiplexer (Embedded Peripheral) -> is it possible to concatenate such several multiplexers?
The Avalon ST Multiplexer iself has 16 input interfaces, but I need to multiplex 20. How is it possible?
Thanks!
ラベル(1)
0 件の賞賛
9 返答(返信)
sstrell
名誉コントリビューター III
1,845件の閲覧回数
No reason why not.  Just connect them together in Platform Designer.
amildm
高評価コントリビューター I
1,843件の閲覧回数
Let's say I concatenate them in the following way:
So, how will the inputs in0 through in19 be scheduled on the OUT output?
The in0 .. in19 are packet based 16bits width inputs (with start-of-frame and end-of-frame signals).
How should I configure the MUX0 and MUX1 so that on the OUT port will be observed packets in0, in1, ... in19 in this certain order (in0, in1, ..., in19)?
Thanks!
Wincent_Altera
従業員
1,803件の閲覧回数
amildm
高評価コントリビューター I
1,787件の閲覧回数
The Avalon-ST Multiplexer doesn't have the Packet User Signal, only Start of Packet and End Of Packet.
Again, as for the picture below,
Thanks!
Wincent_Altera
従業員
1,644件の閲覧回数
Thanks sstrell for helping to answer on behave.
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
amildm
高評価コントリビューター I
1,630件の閲覧回数
The proposed solution is under test, will update the thread with the results
sstrell
名誉コントリビューター III
1,781件の閲覧回数
I would think you should have cascading muxes so a total of 3: in0-in15 on one, in16-in19 on the second one and the outputs of those two selectable through a third one.
Wincent_Altera
従業員
1,564件の閲覧回数
Wincent_Intel
Wincent_Altera
従業員
1,483件の閲覧回数
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
返信
