FPGA Intellectual Property
6670 Discussions
Avalon - Wishbone Interface
Well, I get that IP-Module from opencores.org: http://opencores.org/?do=project&who=a_vhdl_can_controller
So far so good. My problem is, that this IP uses a Wishbone Interface and I need an Avalon Interface.
I tried to do convert it with comb. logic(can_top_vhdl.vhd) but it doesnt work. The old top level entity was can_top.v. Can somebody tell me what I am doing wrong?
PS: I get a warning in the SOPC-Builder:
"byteenable[4] width must be one eighth of data width(8)" I dont have any glue why I get this warning. I got a Nios II CPU with 32 Bits and my byteenable signal is 4 Bits wide.
You are better off looking at www.niosforum.com. I believe that there is an avalon version of this core already. If not, there are walk throughs. wishbone and avalon are very similar.
--dalon
from your file can_top_vhdl
your data port is 8 bit wide to avalon, so no need for byteenable.
if you add a 4 bit byteenable then your data port is 32bit wide.
byteenable[3] is data[31:24]
byteenable[2] is data[23:16]
byteenable[1]is data[15:8]
byteenable[0] is data[7:0]
so you have 2 possabilities
remove byteenable
extend data port
Well thx, I found some finished core(avalon) on niosforums.
It also doesnt work without byteenable. I just know now, that the wishbone interface is very bad documented.
Hi Walther,
I also had to connect Altera avalon bus to whisbone! I found this document on Wikipedia (below the link)
http://en.wikipedia.org/wiki/wishbone_(computer_bus) (http://en.wikipedia.org/wiki/wishbone_%28computer_bus%29
There is a section named "Comparison", it helped me a lot!
Thanks for your help. I found some clue now .
