FPGA Intellectual Property
6424 Discussions
Avalon to AXI bridge
BQi
I did know that Qsys can translate avalon to axi or axi to avalon transparently. but can we get the translation bridge text code?
We would use them outside qsys. thanks
Kenny_Tan
Any reason that you want to do it outside qsys? We don't recommend user do that as the translator added by the qsys automatically. Doing it outside the qsys might hit a lot of problem, your functionality might broke down if you did not test it correctly in the simulation.
You can look into what interconnect had been added in the qsys.
BQi
I need Avalon to AXI cross-clock domain bus transform component But I can not find it in platform designer. Only have single clock domain component. Do you have the idea?
Kenny_Tan
are you using Pro ediiton or standard edition? I will look for you.
BQi
Pro 20.1 or 19.4 is ok Thanks and Best Regards! Brand Qi / 齐闯 Arrow Electronics Tel: 010-56064176 or 13911556862 Email: brand.qi@arrowasia.com<blocked::blocked::blocked::blocked::blocked::blocked::blocked::mailto:brand.qi@arrowasia.com> Addr: 28/F, Taikang Financial Tower, 38 North Street of East 3rd Ring, Chaoyang District, Beijing
Kenny_Tan
If you connect it in the qsys, you will find the name for it.
In the system -> show system with platform designer interconnect, it will show all the translator or extra interconnect over there.
However, for pro edition:
Translator is meant to be used inside the interconnect with transform. Its parameterization depends on overall system configuration and can be correctly done by the transform. Hence the transform was removed from IP catalog. It still gets generated as part of interconnect.
It would be engineering decision to remove it. If you would like to look into the real design, you will have to look into the standard edition.
pdewanga
Hi Team,
May I know how AXI4 interface are converted to AVALON MM interface, I have a DDR4 with Avalon controller interface But my design has the AXI4 interface.
Will the axi-bridge ip from qsys is good enough to do the task ?
