I was testing the sample (http://www.alterawiki.com/wiki/reference_design:_gen2x4_avmm_dma_-_arria_v) in the wiki in my Arria V starter kit, and tweaking a little the parameters (enabled bursting in BAR2) and initializing the onchip memory with some data.
I noticed that in the host PC, with a small Linux driver, half of the data read from the PCI bus memiory was repeated: of every 256 bytes, the second half was repeated from the first half. The cause appeared when trying to run a simulation (lesson learned: always generante simulation files in Qsys and at least load the simulation), Modelsim complained with a compilation error. HPRxmReadData_i and other ports had inconsistent sizes (128 in Verilog Source, and 256 in the code generated by QSys). The fix : in the file <quartus installation dir>\ip\altera\altera_pcie\altera_pcie_hip_256_avmm\pcie_256_avmm_port.tcl , look for the procedure add_pcie_hip_port_avmm_hprxmaster and change set rxm_data_width 256 by set rxm_data_width [ get_parameter_value DMA_WIDTH ] Hope this helpsLink Copied
Hi Ramon, Thank you for sharing this finding, indeed true in v15.0 theparameter rxm_data_width was fixed to 256.
--- Quote Start --- I was testing the sample (http://www.alterawiki.com/wiki/reference_design:_gen2x4_avmm_dma_-_arria_v) in the wiki in my Arria V starter kit, and tweaking a little the parameters (enabled bursting in BAR2) and initializing the onchip memory with some data. I noticed that in the host PC, with a small Linux driver, half of the data read from the PCI bus memiory was repeated: of every 256 bytes, the second half was repeated from the first half. The cause appeared when trying to run a simulation (lesson learned: always generante simulation files in Qsys and at least load the simulation), Modelsim complained with a compilation error. HPRxmReadData_i and other ports had inconsistent sizes (128 in Verilog Source, and 256 in the code generated by QSys). The fix : in the file <quartus installation dir>\ip\altera\altera_pcie\altera_pcie_hip_256_avmm\pcie_256_avmm_port.tcl , look for the procedure add_pcie_hip_port_avmm_hprxmaster and change set rxm_data_width 256 by set rxm_data_width [ get_parameter_value DMA_WIDTH ] Hope this helps --- Quote End --- Thanks for sharing this.
Hi ramon_garcia,
Thanks for the resolution. It is helpful.
