When using this component with QSYS (even with a simple example) a compilation error is obtained, because tlbfm_out is declared as OUTPUT in the VHLD/Verilog that references the component pcie_256_avmm_port, when it should be INPUT.
The fix is simple In the file <quartus instalation directory>\ip\altera\altera_pcie\altera_pcie_hip_256_avmm\pcie_256_avmm_port.tcl in the lines add_to_no_connect tlbfm_in 1001 out add_to_no_connect tlbfm_out 1001 in replaces "out" by "Output" and "in" by "Input". Best regards.Link Copied
Thanks lot for sharing.
By the way, you might also want to report this to Altera to get them fix the bug.
