I am using the avalon memory mapped bridge to interface the FPGA with an external DDR2 chip. The naming conventions are a little confusing to me. In the DDR2 SDRAM controller uniPHY IP, I see a field - Maximum avalon-MM burst length, whereas in the avalon MM pipeline bridge IP, I see - Maximum burst size. My understanding is that they are the same. Reason - I looked at the interconnect on qsys, and I see no burst adapter being used. However, this is my understanding and I might be wrong. Can someone confirm this for me? Thanks, VK- Tags:
- avalon
Yes, they are the same.
In DDR2, the port name is avl_size which have the same meaning like burst size in Avalon MM pipeline. (This message was posted on behalf of Intel Corporation)
