- Email to a Friend
Dear Sirs and Madams,
i try to test CIC ip core. My parameters are: Input Sampling rate 120MSPS System Clock 120MHz Decimation rate 120 Input Channels 16. Problem is core does not generate start of packet and end of packet signals(of course i have this signal i code). Also i see result on wrong channel. Can anybody say something about this?Link Copied
- Email to a Friend
My advice is to run simulation first of all, rather than using hardware captures. With sim you can follow events from the start while with hardware if a fault occurs anytime it will propagate through and gets hard to debug. There is also possibility of timing errors or fifos/rams getting out of control.
Topic Options
