FPGA Intellectual Property
6260 Discussions
COMPLETION TIMEOUT CONFIGURATION IN P-TILE AVMM IP FOR PCIE
rkv
I want to configure the completion timeout value of P-tile AVMM IP for PCIe. I didn't see any option to do so in the IP. Can anyone help me out with the issue?
rkv
Kindly note that we are using Intel P-Tile AVMM IP for PCIe, not Intel P-Tile AVST IP for PCIe.
Rahul_S_Intel1
 Kindly note the completion time out is been disabled in stratix 10 , irrespective of Avalon ST or MM
rkv
Could you please make it clear? Does 'disabled' means
1)CTO value can't be changed. If so what's the default CTO value?
2)Completion Timeout won't happen. So the P-Tile IP for PCIe will wait for the response indefinitely
rkv
we are stuck at this point, kindly reply
Rahul_S_Intel1
>> I do not have a default value for the completion time out
No, Timeout will happen, the time out is implemented in HIP ( Hard Ip)
Only difference from other family of Intel FPGA devices is that , customer cannot change the Time out value ,. The Time out will happen by the default value in HIP.
