FPGA Intellectual Property
6262 Discussions
CORDIC IP on EP4SGX70DF29C2X using Altera 15.1
VBart
for some reason i cannot generate the CORDIC IP for target device EP4SGX70DF29C2X.
I tried other speed grades and they work fine.
Any reason for this?
Thanks!
CheePin_C_Intel
As I try with the ALTERA_CORDIC IP -> Performance -> Check Performance, it seems like the IP does not work with the SIV part with -2X. I am not sure about the specific restriction for this with -2X speed grade device. As a workaround, it is recommended for you to choose other part with speed grade than -2X to proceed with the ALTERA_CORDIC IP. Sorry for the inconvenience.
Thank you.
CheePin_C_Intel
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
