FPGA Intellectual Property
CVI distortion
hi,
I'm experiencing distortion in my VIP path where I'm mixing two video streams:
TPG (800x600p RGB) -> MIXER_DIN_0
CVI (640x480p RGB) -> FRAMEBUFFER -> MIXER_DIN_1
The VIP chain is using a 50MHz system clock.
The MIXER outputs 800x600p RGB 3 colorplanes(colorbars) in parallel @60Hz using a 40MHz clock.
The CVI is clocking the 640X480 video stream inn using a 25.175MHz clock. The FRAMEBUFFER is setup for frame dropping/repetition. I'm pretty sure the 640x480 stream is correct prior to the CVI as I have clocked it out to a screen. However, when I provide the 640x480 stream to the CVI I'm getting distortion in the 640x480 overlay of the 800x600 video output. Can anyone provide som pointers here ? If this is timing related, how can it be fixed ?
Saber890
It seems I managed to figure this one out.
The Framebuffer read/write masters were accessing the same DDR2 SDRAM memory locations as an deinterlacer was using.
This was causing the strange patterns in the output video. I changed the memory location for the FrameBuffer and now the output distortion is gone.
Saber890
