FPGA Intellectual Property
6259 Discussions
CVI overflow and CVO underflow
CVI(run control) -- CVO(run control) ,
cvi always overflow,cvo always underflow. why? How to set the fifo depth?
nios config code is as follows,
/**************************** CTI **************************************/
printf("/*******************************************\n");
printf("CTI_control is %x!\n",CTI->control );
printf("CTI_STATUS is %x!\n",CTI->status );
printf("\n");
// updata control data
CTI->control = 0x0006;
// set go bit 1
CTI->control = CTI->control | 0x0001;
printf("After config.\n");
printf("\n");
// /************************** ITC ****************************************/
// mode1 HD
// disable mode1_valid
ITC->mode1_valid = 0;
// set mode1 registers
ITC->mode1_control = 1;
ITC->mode1_sample_count = 1920;
ITC->mode1_f0_line_count = 540;
ITC->mode1_f1_line_count = 540;
ITC->mode1_hfront_porch = 0;
ITC->mode1_hsyn_length = 0;
ITC->mode1_h_blanking = 720;
ITC->mode1_vfront_porch = 0;
ITC->mode1_vsync_length = 0;
ITC->mode1_v_blanking = 22;
ITC->mode1_f0_vfront_porch = 0;
ITC->mode1_f0_vsync_length = 0;
ITC->mode1_f0_v_blanking = 23;
ITC->mode1_active_picture_line = 21;
ITC->mode1_f0_v_rising = 561;
ITC->mode1_field_rising = 564;
ITC->mode1_field_falling = 1;
ITC->mode1_std = 0;
// ITC->mode1_sof_sample;
// ITC->mode1_sof_line;
// ITC->mode1_vcoclk_div;
ITC->mode1_ancillary_line = 9;
ITC->mode1_f0_ancillary_line = 571;
// enable mode1_valid
ITC->mode1_valid = 1;
// mode2 SD
// disbale mode1_valid
ITC->mode2_valid = 0;
ITC->mode2_control = 3;
ITC->mode2_sample_count = 720;
ITC->mode2_f0_line_count = 288;
ITC->mode2_f1_line_count = 288;
ITC->mode2_hfront_porch = 0;
ITC->mode2_hsyn_length = 0;
ITC->mode2_h_blanking = 144;
ITC->mode2_vfront_porch = 0;
ITC->mode2_vsync_length = 0;
ITC->mode2_v_blanking = 24;
ITC->mode2_f0_vfront_porch = 0;
ITC->mode2_f0_vsync_length = 0;
ITC->mode2_f0_v_blanking = 25;
ITC->mode2_active_picture_line = 23;
ITC->mode2_f0_v_rising = 311;
ITC->mode2_field_rising = 313;
ITC->mode2_field_falling = 1;
ITC->mode2_std = 0;
// ITC->mode2_sof_sample;
// ITC->mode2_sof_line;
// ITC->mode2_vcoclk_div;
ITC->mode2_ancillary_line = 8;
ITC->mode2_f0_ancillary_line = 321;
// enable mode2_valid
ITC->mode2_valid = 1;
printf("ITC control is %x!\n",ITC->control );
printf("ITC status is %x!\n",ITC->status );
// enbale control, cvo output data
ITC->control = 0x1e;
ITC->control = ITC->control | 0x01;
This is normal that the CVI overflow or CVO underflow if without a frame buffer at between.
In the real system this is suggested to have a frame buffer: CVI-> FB -> CVO.
Terence
(This message was posted on behalf of Intel Corporation)
