FPGA Intellectual Property
6666 Discussions
CXL type 3 design example Design Assistant Errors
brian1211
In building the CXL Type 3 example design in Quartus Prime Version 23.1.0 Build 115 03/30/2023 SC Pro Edition I get some CDC errors.  I do not see them with the 22.4 build.
CDC-50001 - 1-Bit Asynchronous Transfer Not Synchronized 1
RES-50001 - Asynchronous Reset Is Not Synchronized 2
RDC-50001 - Reconvergence of Multiple Asynchronous Reset Synchronizers in Different Reset Domains 3
TMC-20025 - Ignored or Overridden Constraints 4
TMC-20026 - Empty Collection Due To Unmatched Filter 5
FLP-40006 - Pipelining Registers That Might Be Recoverable 6
CLK-30032 - Improper Clock Targets 7
LNT-30010 - Nets Driving both Reset and Clock Enable Signals 8
JonWay_C_Intel
Generating and compiling the example design. Will update you if same observation.
JonWay_C_Intel
These DRC Checks were enabled late in 22.4 onwards. These errors are expected for 23.1 and expected to be fixed by 23.3.
brian1211
So the build should work fine in a system and shouldn't experience any CDC issues with the given errors correct?
JonWay_C_Intel
yes, DRC violations are not impacting the functionality so far.
JonWay_C_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
