accroding to the spec <ug_embedded_ip>P15-4,the descriptions for parameter 'FIFO depth',legal value is ONLY 1~32.
But when I use Qsys ver 12.0 to add the DC_FIFO component,I can type in '1024' to the parameter 'FIFO depth' of DC_FIFO,without error reminding. What is it?Can FIFO depth of DC_FIFO exceed 32? Thanks for any reply. Regards!Link Copied
That's a documentation error. I don't know what the maximum is but I know it is much larger than 32. I've used 1k before so you should be fine with that setting.
Thank you very much!
And yesterday when I use Qsys,type in '2000'to FIFO depth,it reminds me that "the FIFO depth has to be a power of 2."I think it may be a error in the doc or I confused it.- Mark as New
You are better off rounding that up to 2048. The memory blocks in the FPGA which make up the storage element of the FIFO have densities that are a power of two. I have flagged these documentation errors so they should be corrected the next time the document is updated.
Thank you again~
