FPGA Intellectual Property
6356 Discussions
Can FrameBuffer be connected to onchip-FIFO,and then to SGDMA?
Hello,now I design a custom board using cyclone IV EP4CGX15 to transfer video to our SOC.
And now there is no on-board external RAM connected to FPGA,so I have to use on-chip memory.
For I just transfer the video without any processing.can I connect the FrameBuffer's out to onchip-memory?
It is said in the spec that the FrameBuffer buffers frame data to EXTERNAL RAM.
For If I connect FrameBuffer---->onchio-FIFO(opt)---->SGDMA.
Does this link have any problem?
Thanks for any suggestions.
Regards.
Just connect simple 1 port 32bit wide RAM to SGDMA and that's it. No point to use FIFO.
Socrates,Thank you very much!
Sorry for I'm so newbie in FPGA,I'm not quite clear about your meanings.
I think I didn't express our applications pretty clear.
We want to use FPGA to act as a Bridge which sends raw video data to out SOC through PCIe.
And use SGDMA to send video data to PCIe IP provided by altera.
You mean that I should use a dual-port RAM?
Just like "FrameBuffer--> DualPort RAM--->SGDMA“?
Regards!
I'd offer to download framebuffer demo from alterawiki.com :)
What is the resolution and bit depth of the video you want to frame buffer?
Do you want a double or triple buffer?
You will almost certainly not have enough on-board memory if you have video of any
significant size.
For instance, to triple buffer color video at VGA resolution, you would need a minimum of
24 (bits per pixel) * 640 (columns) * 480 (rows) * 3 (buffers) = 21,600 Kbits
of embedded memory, which not even the largest Cyclone V devices are supporting.
You will almost certainly need an external SDRAM or SRAM in order to frame buffer your video.
--- Quote Start ---
--- Quote End ---
Thank you gwall.
The FrameBuffer write video buffer to RAM with address is added.
I thought I can Link FrameBuffer to onchip FIFO in Qsys.
It should be wrong.The FrameBuffer write data with the writing address is added after every write cycle,not write to a constant address.
Thanks Socrates.Regards!
