FPGA Intellectual Property
Cannot upgrade PLL IP
PDone
I am trying to run IP that I am using is upgraded.the IP Upgrade Tool. Most of the IP that I am using upgrades, but PLL Intel FPGA v!*.1 does not.
When I create an instance of the PLL using the Megawizard plug in, it works fine and it shows up in the Hierarchy listing  and the IP Components listing.  When I click on the instance, it does not open the Megawizerd and says that
PLL Intel FPGA v18.1 could not be found in the specified library path
Other IP does open the Megawizard.
What is the issue?
Ash_R_Intel
PDone
THX.  I also have the same problem with the Altera Unique Chip ID.  what file should I modify?
Ash_R_Intel
Hi Peter,
Please try out this solution provided in this article:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ip/2018/failed-to-launch-megawizard-plug-in-manager--altera-unique-chip-.html?wapkw=unique%20chip%20ID
Please note that Chip ID IP is supported for following devices only:
Stratix 10
Arria 10
Cyclone 10 GX
MAX 10
Stratix V
Arria V
Cyclone V
Additionally you can follow Chip ID Intel FPGA IP Cores User Guide
Regards.
