Hi, I'm using 1G/10G PHY IP in my design. After power-up the IP is wake up by default in 10G mode. switching to 1G mode is done by reconfiguration of the IP (using Transciever Reconfiguration Controller). My question is how can I change the behavior so that after power up the IP would be wake up in 1G mode?
HI MTwee,
Unfortunately no. BY default the IP is configured to start with 10G first then to be reconfigure to desired data rate.
O.K,
Thanks for your answer.
regards,
Moshe
