Hi, I'm trying to implement a design at a sampling rate lower than the clock frequency.
So i implement this by a Clock_Derivered Block. I'm using a Altera Cyclone® IV EP4CE22F17C6N FPGA. The main clock i'm assinging it to PIN_R8 as said in the DE0_Nano_User_Manual. The circuit is in the image attached. In CLK_LOW parameters i ticked "Export As OutPut Pin". Now the problem is that i would like to view this clock with the oscilloscope but i don't know where does this block export the clock to....neither if i have to assign the pin or how to assing this OutPut Pin.Link Copied
I solved it.
The Clock_Derivered Block needs an input of the crystal and on that board we only have an 50Mhz crystal source at PIN_R8. I used an DSP Builder Incrementor Block and a bus splitter for the Clock_Derivered Block and assigned to it.
