FPGA Intellectual Property
6670 Discussions
Coefficient reload problem of FIR IP core
LYW
Dear all,
         I am using Quartus II (Prime 18.1) to write verilog program, hoping to realize coefficient reload of FIR IP core, and the simulation results through ModelSim are correct, and all signals actually entering FIR are correct through signal tap.
        However, the actual data from FIR is still the data before parameter overload, that is to say, the FIR Coefficient reload does not play a role in the actual operation.May I ask what causes this?
Thanks in advance,
LYW
